SBC Roller Rocker Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2006, 12:43 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I confess to not knowing much about rocker ratios and related matter but am wanting to move to roller rockers on my SBC built with Edelbrock Peformer cam, manifold, and carb.
I am running s reworked 993 iron heads with dished pistons.
Am thinking of using the stamped rocker arms with the roller tips.
The stock ratio is 1:5. What would going to 1:6 do for me?
What size stud do I most likely have in these heads? 3/8 or 7/16?
Old 12-04-2006, 12:50 PM
DoubleVision's Avatar
The heads have 3/8 studs. Moving up to a 1.6 ratio rocker will raise the lift by .030, and the move the duration up by about a degree. Example, if the lift is given at .450 with a 1.5 ratio rocker, the 1.6 will make it .480.
However, make sure you use a quality name brand like Crane, Comp cams, isky, etc. the off shore brands like proform are a bit cheaper, but the quality is less and the ratio isn`t accurate, you get what you pay for. factory rockers are reliable but aren`t accurate either, they are given at 1.5, but there really around 1.4.
Old 12-04-2006, 10:44 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you go to the higher ratio rockers make sure the pushrod doesn't contact the head along the side of the pushrod hole. You may have to elongate that hole a bit.
Old 12-04-2006, 11:37 PM
Don't waste your money with roller tip rocker arms, they wont give you any more HP, go full roller or stamped. DoubleVision is right, you get what you pay for. A lot of times the price difference isn't that much if you shop around.
If you go from 1.5 to full roller 1.6 you should get someting like 10-15hp.
One last note, I would never trust aluminum rocker arms on a street car, get a set of comp cams pro magnum roller rocker arms.
Jordon
Roller Cam Help Please Sbc 1985fiero Engine 3 06-21-2006 10:57 PM
SBC 1.7:1 rocker arms lluciano77 Engine 36 03-11-2005 12:33 AM
Roller rocker adjustment pcesak Engine 1 06-01-2003 05:33 PM
roller rocker / madmax Engine 1 11-17-2002 06:49 PM
Roller Rocker arms bigjoedo Engine 1 08-27-2002 05:30 PM
