SBC rollerlink timing chain - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 11:19 AM
Hello, I need some help, I bought a Napa roller timing set for my 350 sbc
This is the crank gear that has three keyways to line up the cam timing @ std. or 4 deg. before or 4 deg. after TDC. I have new chain and gears but I trashed the package that it came in. The THREE keyway slots are as follows #1 Round on top edge of key. #2 Pointed at top and, #3 Flat at the top edge. I think the round is the factory type setting. Any help?
Thanks
Ricksgtx
Old 10-10-2010, 12:01 PM
327NUT's Avatar
You're right, "O" is factory or straight up...the triangle shape is 4 deg. adv....and the flat or square is 4 deg ret.
I let my timing chain slip and cant find TDC Berg Engine 4 07-19-2009 01:25 AM
Timing chain noise? V8 Kid Engine 2 06-10-2009 05:39 PM
engine timing sbc 350 or 327 don't know Carlos9 Engine 4 06-10-2009 04:56 PM
Correct Timing Chain Tension mouseman Engine 7 09-20-2005 08:43 AM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
