SBC rough idle and running - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2013, 01:46 AM
I have a 1988 350 SBC that ran great on the way to work today, started it at lunch got rough idle and rough while accelerating. Does it with the engine cold and at running temp.
Plugs look good, choke is working and no vacuum leaks.
What's up?
Old 05-11-2013, 04:53 AM
Richiehd's Avatar
JS-70
Figure out which cylinder is missing and go from there. Start with a compression test, and check for a bad plug wire.
Old 05-11-2013, 09:45 AM
1badLemans's Avatar
I agree. Do a really thorough visual check of the ignition parts. Take off the cap and check condition of it and rotor also check condition of coil. I have seen timing get out of wack due to a dist hold down not being tightened. Check timing. if these check out. Then go through your carb. If that is good you might have some more serious problems. Compression test is in order. Maybe adjust valves etc... good luck
Chevy 350 running rough at idle The Raven Engine 3 01-07-2010 03:54 PM
SBC 350 running very rough at idle 75gmck25 Engine 3 02-03-2009 05:38 PM
rough running, good idle... SecGenLvr Engine 19 02-09-2006 03:43 PM
rough running higher then idle Trucks55 Introduce Yourself 2 01-15-2006 03:33 PM
