SBC Runnin like junk - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2002, 06:03 PM
Harlequin's Avatar
Post SBC Runnin like junk
Hi, I have a 91 sbc with throttle body injection. I recently had a fuel pump go bad and replaced it. Shortly after my car died and I replaced the fuel filter and all was well for about 25 minutes. After that time period the car would only goto about to 2500 rpm and had no power...but would idle fine. Now the car is not running at all, bad TB injectors? HELP!!
Old 07-08-2002, 07:45 PM
axle bastard's Avatar
you're killin me buck!
Post
does it have a fuel pressure regulator?
i dunno, i know drive line.
you should be able to jump out 2 prongs in the aldl to get trouble codes from the ecm.
i don't know what the procedure is off hand, i have done it a couplea times tho. if no one else knows, i can find out.
i bet some one will know.
i hope this is some how helpful
Old 07-08-2002, 09:53 PM
4 Jaw Chuck's Avatar
Post
Did you bleed the fuel system? Sounds like you have an air lock. Do you get fuel at the rail now?
— Han Solo
Old 07-09-2002, 07:02 AM
Harlequin's Avatar
Post
No I havent blead the system yet, yes fuel is getting to the injectors, but barley, just a drip or two.
Old 07-09-2002, 07:31 AM
Tom Tom is offline
Post
there should be a tirevalve type bleeder near the TB push the pin and turn the engine over till all the air is out,if any air is in it you won't get proper fuel pressure(air is compressable,liquids aren't)
