Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC -> S10 build
Old 09-24-2012, 11:03 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
If the engine is not in the truck,change the cam first.That way you can get a good seal on the pan,check everything before installation.If you are going to put the heads on at the same time maybe get a gasket set and check everything
