Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC -> S10 build
Old 09-26-2012, 09:57 AM
my87Z's Avatar
my87Z my87Z is offline
Veteran/Firefighter-Paramedic
the lunati 00012 specs are 246 @ .050" and 300 advertised with .515" lift and 108LSA. on the card it says the operating range is 2500-6500, which is crap, the true operating range of this cam is more like 3500-6500. if you use this cam i would recomend the 200cc platinum heads. you will greatly benifit from them at 4500rpm and up. with this cam you could also go with a 3500-3800 stall. go with a 4779 holley 750dp. as for the springs you will need to match the seat and open pressures that are recomended for the lunati 00012 otherwise you will wipe the lobes right out.
