SBC sheet metal intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2008, 07:38 AM
Vortech 4.3's Avatar
jack of all trades
when guys are making these. the runners, where they butt up next to each other at the ports. how do they weld these ? i see them welded on the outside all the way around. but there is no way to get a tig torch in between runners that are right next to each other. how do they do it ?
Old 01-19-2008, 11:24 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I think I know what you're looking for, if I was fabricating a sheet intake, I'd shape the runner ends to fit inside the flange opening, and weld them at the flange from the bottom, does that make sense? Just make the flange opening large enough so that when the runner tube is fitted inside it's large enough to port match after welding.
Old 01-19-2008, 11:33 AM
jack of all trades
yeah, i thought of that, and variations of it. but i have seen pics where they didn't do it like that. maybe they just weld that section from the inside. or they weld the runners together, then weld the pair to the flange.
Old 01-20-2008, 08:08 AM
jack of all trades
anyone ?.....
Old 01-20-2008, 05:45 PM
DOINSND's Avatar
More HP
have you seen this one
Old 01-20-2008, 06:02 PM
jack of all trades
no, i haven't. is that a WILSON ? that is really close to what i want to build. any bigger pics ?
Old 01-20-2008, 06:06 PM
jack of all trades
they had to weld the runners together. then weld them onto the flange on the outside.
looking closer, it looks like that is for BRODIX heads. the ports are not close enough to be vortec heads.
Old 01-20-2008, 06:08 PM
DOINSND's Avatar
More HP
go to this website really cool 4.3L engines
www.raceprovenmotors.com
Old 01-20-2008, 06:16 PM
DOINSND's Avatar
More HP
this one is spread out
Old 01-20-2008, 06:18 PM
jack of all trades
oh-yeah, RPM. i forgot about those guys. check out the 1100 hp 4.3
i was going to buy a set of sheet metal valve covers from them. (i can't find them on their site). but they did not look the way i wanted, so i didn't get em.
Old 01-20-2008, 06:22 PM
DOINSND's Avatar
More HP
On their website you click on service on top it directs you to their products
jack of all trades
thats even closer to what i want. where are you getting those pics ?
Old 01-20-2008, 06:24 PM
DOINSND's Avatar
More HP
Old 01-20-2008, 06:36 PM
jack of all trades
found em. what they have
http://www.raceprovenmotors.com/cart...products_id=64
the style i want.
http://store.summitracing.com/partde...5&autoview=sku
Old 01-20-2008, 06:54 PM
Last journal entry: more...
I can tell ya I'd start fab'n intakes and valve covers like that if aluminum was so frick'n expensive!
Intake Manifold won't fit Andrew7dg Engine 18 12-15-2008 08:27 AM
Need Sheet Metal Welding Help cab Body - Exterior 28 02-19-2007 04:25 AM
sheet metal work robs ss Body - Exterior 2 11-22-2006 04:19 AM
sheet metal questiuon cxpcman Body - Exterior 11 06-09-2006 09:47 PM
SBC intake oil leak, learn from my mistake! pcoghlan Engine 1 06-03-2006 05:29 AM
