sbc shim head gasket leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2012, 07:40 PM
i have a sbc 350 with shim head gaskets & the passenger side head leaks a very little water like a drop then it stops at the back of the block. what could cause this?
Old 09-09-2012, 08:52 PM
BOBCRMAN@aol.com's Avatar
Any kind of defect. Probably a scratch . Put a cube of stop leak in it and forget about it. GM did for years..
Old 09-10-2012, 02:03 AM
any particular brand?
Old 09-10-2012, 05:15 PM
GM is Bars Leak biggest customer.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
the82elco (09-10-2012)
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 2 08-23-2012 07:46 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 03:15 PM
Embossed Shim Head Gasket cc82z-28 Engine 1 06-28-2008 07:35 PM
SBC 400 shim head gasket sb72elcamino350 Engine 4 06-28-2004 07:47 AM
steel shim head gasket stfinney Engine 5 11-08-2002 07:39 PM
