sbc shorty header plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2005, 10:48 AM
stea's Avatar
Need advice on shortie plugs, dont really want to get the Accell plugs. Whats every body running on their SBC's with HEI?
The shorter the better. #7 plug wire is resting on header tube and 1,2 and 8 are to damn close.
Old 05-19-2005, 11:03 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I have the bosch +4 platinum plugs and moroso 11mm plug wires, and none of mine are touching. They are a little close to the headers, but none of them have melted as long as they aren't touching.
Brad
Old 05-19-2005, 11:06 AM
stea's Avatar
do you happen to know the part #?
Old 05-19-2005, 11:58 AM
edge's Avatar
Time is short, are you ready?
Part No. for spark plugs will vary depending on application (i.e. type of head - alum or iron?, compression ratio, n/a or forced induction, etc.)
I would try some heat sheilds for your plug boots. The type discussed on the following thread work great: http://www.hotrodders.com/showthread.php?t=61067, specifically these type: http://cableorganizer.com/insultherm-spark/
Best of luck, Ed www.edgesz28.com
Did You Know?
Old 05-19-2005, 12:08 PM
stea's Avatar
Just your average 350, stock heads, 9 to 1 compression. Natuall asperated. Nothing special.
Old 05-19-2005, 12:11 PM
Last journal entry: PICTURE TEST
plugs
Autolites AR135's get them at any advance autoparts store.... They might need to order them,,2 or 3 day wait..
keith
Old 05-19-2005, 01:54 PM
coldknock's Avatar
keith
I agree and concur wholeheartedly. I used regular of the shelf plugs for a long time until I tried a set of the race plugs. I'll never go back to a resistor plug.
Larry
Don't use cheap wires, pay for he good stuff.
Old 05-19-2005, 02:10 PM
stea's Avatar
THANKS GUYS. Ill give the AR135's a try.
Old 06-05-2011, 01:27 PM
75chev4x4's Avatar
I know this is an old post but what are you guys gapping these ar135 plugs at for the average sbc 350?
Old 06-05-2011, 02:12 PM
75chev4x4's Avatar
I ask because I bought a case of the accel shorty plugs before I heard they were garbage.
Shorty Header Plugs Bluepen Engine 4 05-02-2005 07:28 AM
Close fitting, full length SBC header recommendation PatM Hotrodding Basics 7 11-20-2004 11:48 PM
shortest plugs? Header clearance issues... killerformula Engine 7 09-04-2004 10:07 PM
? about the soft plug's in my 350 sbc bowtieorbust Engine 3 07-04-2004 08:41 PM
SBC Header Dimensions Dave E Shank Engine 1 03-08-2004 01:47 PM
