This is not to uncommon an event with a high lift cam. You'll most likely need to lay your hands on a set of tall covers.
I think your lift is a bit tall for a ball fulcrum rocker, you should seriously consider something with a roller fulcrum. It won't take long before the ball will fry with this much lift while working against the spring pressure to close these valves. You're not in super serious territory but a half inch lift is about the reliability limit for those things. Bogie |
Tall Valve Covers?
Thank you for the response- But I'm confused regarding your 'tall valve cover' comment?
The rockers are hitting the side of the covers (closest to the pushrods), not the the top. Unless taller valve covers are also wider somehow, I don't see how it will help. It's almost like if I could grind off a few 32nds off the back of the rockers, my problem would go away.. Elm |
I assume you are using stock covers? If so, make sure you have them on correctly. They do have a very slight angle to them and if you have them backwards, the pushrod end of the rocker will rub the cover.
Mark |
Interesting.. I'll need to look more closely-
One side of the cover has a continuous lip and the other side only has a lip for a portion of the length. Both the stock aluminum L-46 covers and the chrome aftermarket cover that I'm using have the same configuration. I put them on with the full lip towards the exhaust side the the partial lip towards the intake side. Please let me know if this is incorrect? Thanks! Elm |
If snugging up on the nuts seems to have solved the problem, it sounds like a vertical clearance issue. But however it is hitting, it might work as well to get the newer silicon gaskets to add height, rather than using tall covers.
Pat |
Bogie |
Bogie,
The rocker arms are hitting low on the intake side of the valve cover- About 1" up from the gasket surface. It's the rear 'tip' of the rocker arm that is making contact with the cover- Back by where the pushrod sits. This has nothing to do with height or lift of the cam, it actually appears to be hitting more at the bottom of the cam travel when the rocker tends to 'wobble' due to the solid cam lash. I am running a solid flat lifter cam- No roller cam. The heads are brand new out of the box and the block was only mildly decked (.005) to clean it up when I had it bored. I used one of those Manley rocker geometry checkers and the pushrod length appears to be dead-on to the valve tip. Thoughts? Thanks! Elm |
Maybe it's the redneck in me, or the fact that I've spent two days making large by huge rotors and calipers fit on my GTA but either way it sounds to me like you need to introduce your valve covers to Mr. ball-peen hammer
If you want it to look pretty you could use a lead bag and a wooden dowel and get those few 32nd's ...Assuming they're steel. If they're cast aluminum a die grinder could convince them to play nice.. Seriously, there are ways to add that little clearance without it looking bad, if it's noticeable at all..I've had issues with the small, center bolt type, valve covers and if after checking to make sure all is well engine wise (like it sounds like you have) I just "help" them along. |
Tall valve covers
I have had this problem before, and seen it many times at the track. 26/28 sounds sort of like a Speedway cam. If everything is set right, and the engine runs great, and you set the lash hot, not cold, try the rubber valve cover gaskets and a set of steel, thin-wall valve covers from PAW, tall stlye. These you can actually manipulate by hand. Let them sit in the sum or boil them, and sort of form them by hand. If you are not into looks, Mr. Ball-peen does the job perfectly. Don't use the pretty aftermarket thick covers. Don't adjust the valves with a deep socket--it pushes down on the balls and gives a false reading.
you know I haven't seen this problem in a number of years and rereading your original thread I saw these are Elgin rockers. Thinking back to when Elgins were popular, this was a fairly common occurance. It seems the Elgin has a little more meat, as did Isky and Howard versions, than the GM rocker and certainly more modern designs by Crane, Comp, etc.
As has been suggested you can dimple the covers with a ball peen, and sometimes doubling the gasket helps. Another trick is to use a raised guide plate (<<<http://www.competitionproducts.com/prodinfo.asp?number=8032>>> for a picture). This takes some of the side to side rotational movement out of the rocker by supporting the push rod at a higher location. Check the inside of the guide for clearance to the push rod, this should not touch at any lift point. If it does the pushrod will bind and a few things can happen, the obvious is the push rod bends but the other is that the push rod tries to pull the rocker back toward the rocker cover, it's not much but might be just enough. Finally you can kiss a little metal off the back side of the rocker, while shape and thickness provide strength, the load on the rocker behind the pushrod pivot point isn't nearly so high as loads between that point and the valve tip so it can sacrifice some metal on that back side. Bogie |
| valve lash on a bbc solid cam | elanum70velle | Engine | 4 | 07-01-2006 10:45 AM |
| Comp Polymer valve covers, how to baffle? | Arkie 355 | Engine | 3 | 04-11-2006 10:32 AM |
| Re; Finally Found The Best Valve Covers, 2piece Sbc | ALASKAN | Engine | 7 | 04-16-2005 11:01 PM |
| Need help with older sbc valve covers | 69C10 | Engine | 4 | 04-13-2005 09:33 AM |
| Tall valve covers needed? | KeithB123 | Engine | 15 | 02-03-2004 12:54 AM |
