sbc starter issues yet again - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2013, 01:37 PM
Project89's Avatar
recently i replaced the flexplate and starter in my camaro but its still grinds now and then.usually only when hot out or if the battery is a lil low
ive tried with shims, without shims and its always the same.
somone told me to cut a shim in half and only shim the outer bolt have any of u guys head of this before ?
btw this is an offset bolt pattern starter 168T flexplate
the engine is 9.2-1 cr so not high by any means
Old 06-21-2013, 02:14 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Could the nose of the starter made to fit a 153 teeth flexplate? Not a 168.
The Following User Says Thank You to lg1969 For This Useful Post:
Rexter (07-07-2013)
Old 06-21-2013, 03:28 PM
Project89's Avatar
not sure what u mean
edit
my understanding to use a 153T flexplate and starter i would have to drill and tap the inner inline bolt hole on the block
Old 06-21-2013, 10:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A page that has some info on shimming a starter is here.
Old 06-21-2013, 10:15 PM
Project89's Avatar
see thats the thing i have one shim in it now and its not noisy at all , just once ina while it will start to crank and then grind which i assume means it needs to go closer , ill try the half shim, was just curious cause i never heard of somone using just half a shim
Old 06-22-2013, 07:27 AM
captainbob's Avatar
1948 KB-1 International Pickup
Actually the instructions in my rebuit starter for a 69 Camaro 327 says to shim only one end if needed. I usually use a large paper clip to space the gears, but the starter came with a piece of wire that was about twice as large for the spacer. Close is not good.
On a chrome mini starter I have used, I had to use double spacers (4) to drop it low enough to get good clearance. I decided not to space one end since it would throw the angle slightly off on the mating surfaces. I was concerned about that but the instructions from the rebuilder did say to use that method.
Old 06-22-2013, 08:21 AM
Greg T's Avatar
www.krusinklassics.net
Is your starter supposed to have a support bracket on the end that bolts to the block?
Old 06-22-2013, 10:39 AM
life is a temporary assignment
I had about five cars with start problems,,, Not sure what going on with these new starters today..They are machined wrong..... I started using this starter on all my cars,, Never had anymore problems... This is a great little starter,,, I even use it on all my big block chevys as well...
Chevy 305 350 454 Mini Racing PMGR Starter High Torque | eBay
Old 06-22-2013, 10:51 AM
Project89's Avatar
thanks i wa slooing at those starters but was unsure ,now that i know somone has used them with good results ill grab one
Old 06-22-2013, 08:52 PM
Project89's Avatar
just wanted to say thanks guys , a single shim on the outboard bolt cured my starter issues.
i even shut the car off and left the fuel pumps/radiator fans running to kill the battery and still had no issues with the starter grinding
The Following User Says Thank You to Project89 For This Useful Post:
NEW INTERIORS (06-22-2013)
Old 07-10-2013, 12:04 AM
for what's it worth, my former neighbor had a chevy 350 that was ALWAYS giving him fits with the starter grinding.
he found a speed shop that told him that some chevy blocks (certain casting numbers I guess) were actually machined wrong from the factory, and the mounting pad for the starter was 'too tall' so no amount of shimming would ever fix the problem.
he bought a new starter, had a few thou milled off of the mounting surface, and never had starter issues again....
he wasn't a diy hot rodder so he couldn't give me any more detail then that.. just something worth looking into
Old 07-10-2013, 12:19 PM
Second the milling fix. DId it many times I always attributed it too cheap repop starter nose castings though. I always tried to avoid the whole problem by taking the dead original starter to a local rebuilder.
Old 07-10-2013, 11:53 PM
Red: i just rebuild them myself :> my engine isn't particularly hard on starters so I don't wear them out too often.. but the heat from the headers causes issues with the solenoids sometimes.
i've thought about going to a mini starter just for more room around the headers *shrug*
SBC starter issues jjack010 Electrical 7 10-28-2012 08:09 PM
sbc starter issues 4inthefloor Engine 2 08-08-2012 09:52 PM
starter issues 1964gasser Engine 6 10-31-2011 05:26 PM
starter issues mkjarobinson Engine 2 06-16-2008 09:40 AM
Starter issues........ muzzfactor Engine 20 06-19-2007 06:05 PM
