SBC Starter movement - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 05:17 PM
i have a 454 w/168 tooth flexplate. well it grinds always. shimmed or not shimmed. shimmed on the out side or both holes. i have the right bolts i.e. the knurled ones. i put a pretty think washer on the out side bolt to bring in the starter. that way a paperclip would fit nicley between the two gears. i have new power cables 0 or 2 gauge cant member. ignition cable is new also. ive used new sumitt mini starters and tons of differ autozone or checkers starter. itll work for a few but then it grinds. like it moves out of place. like it to far away. i did notice the bolt has too much play in the bolt holes. when i go online checkers show a part number the same for many motors. any help would be greatly appriciated!!
Old 01-26-2011, 05:37 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Ther are more then one starter for these are you sure you have the one for the 168 tooth flywheel ?
Cole
Old 01-26-2011, 05:44 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I think GM, makes an OEM a rear bracket, I've seen it mentioned here. A search found 8 pages of posts.
Old 01-26-2011, 06:06 PM
when i went to checkers i asked for a starter for a 454 73 chevy pickup. the kicker is that the part number is the same for a 70 vette 454, 70 vette 350, a 396 and a 400 motor!!!! i have tried that brackette but it still moves. i even custom made one.i think it moves because theres too much play in the bolt holes for the starter. i have looked at different starters for a 454 from diffenret cars and the bolt hole all have play. now the bolts i use are new and are standard size 3/8. the thread is good in the block.
Old 01-26-2011, 06:08 PM
cole- from my knowledge all starter gears are the same. the differences between a small and big flexplate is a small flexplate uses a inline bolt pattern. a big flexplate uses a staggared bolt pattern. mine is a staggard bolt pattern.
Old 01-26-2011, 06:13 PM
Are you using the correct knurled bolts ? Sounds like it's working itself loose.I use Loctite and it works to keep them tight and also a stabilizer bracket that bolts to the side of the block.
Old 01-26-2011, 06:49 PM
My father in laws farm truck does it too. I've put new bolts 2 flywheels, (1 only by me 1st was before I met his daughter) and a new starter from GM no luck I just tighten em often
Old 01-26-2011, 07:19 PM
eloc431962's Avatar
Wiki Edits: 37
You really need to find the proper bracket to keep it form moving around. JMO
It's just going to keep giving you trouble till you give it some support.
Cole
Old 01-26-2011, 07:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Renamed this thread, "Freaking Starter!!!!!" isn't a good description of the problem.
Old 01-26-2011, 07:21 PM
life is a temporary assignment
It's the starter's we now have today.. This has been a big problem lately.. I had this problem on a few Of my cars.. The best way to fix it, Spend the money on a good Mini starter.. That's how I fixed mine.. You will keep fighting it with the over the counter starters.. You can add all the brackets you want.. It WON'T fix the problem..
Old 01-26-2011, 07:38 PM
BOBCRMAN@aol.com's Avatar
I have found that quite a few of the "rebuilt" starters have mounting holes that are wobbled out. The knurled bolt should be almost a press fit thru the starter nose housing. If not, the starter will do the hula!! Been there..
The bracket to the block is a must on BBC's
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
AboveTheLogic (06-18-2016)
4th gear movement sugi Transmission - Rearend 1 08-09-2009 03:51 AM
NO movement cool rockin daddy Transmission - Rearend 5 08-14-2006 02:14 PM
little movement in reverse gm_71chevelle Transmission - Rearend 2 02-20-2006 05:30 PM
No Movement gm_71chevelle Transmission - Rearend 3 02-19-2006 02:26 PM
TH350 - no movement 72BuickGS350Conv Transmission - Rearend 3 10-23-2005 11:56 AM
