Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc starter selonoid "r" wire Confusion
Old 09-15-2005, 07:46 PM
desavedo desavedo is offline
Hello again Doc:
First of all thanks for the reply. I only had a few minutes to look things over, but i tried firing up the car today without the "R" wire in place. Basically, it will ever so slightly make a noise down in the starter area. I don't believe i have enough voltage.
I didn't have a volt meter, but had a test light. when the key is turned over " in the start position" the + terminal on the coil barely has enough juice to power the test light.
Is that normal or do i have a problem somewhere? Also, are you suggesting I run that "r" wire that i am currently not using from the " S" terminal that the ignition is also using, then route that to the + side of the coil?
