Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - sbc starter selonoid "r" wire Confusion
Old 09-16-2005, 09:05 PM
desavedo desavedo is offline
Well i went ahead and had the starter tested and it works fine. It's making a clicking noise, and i took a video if what it's actually doing. If you have high speed internet it's here: . I'm almost convinced that i need to shim the starter as when the starter gear trie's to engage, i think it may be hitting the flywheel. I'll test the voltage at the solenoid tomrrow when in cranking position and shim it if needed and see what i come up with. Thanks all for the help. I'll post results this weekend sometime and hopefully it's good news
wow! I just realized my vid is 42mb., so probably scratch that idea. anyways, I'll definatley be on the forums again this weekend. Thanks Again.
