sbc starter solenoid voltage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2011, 02:16 PM
GMR GMR is offline
While cranking, I measure 9.5v at starter solenoid 's' terminal. Is that normal?
Old 10-27-2011, 02:28 PM
lg1969's Avatar
Google "Tunnel Ram 406"
It would be. you have voltage drops between the battery to the solenoid "S" terminal. You have resistance in the connectors, fuse panel, switches and the wire itself. This circuit will give you the full 12V to the "s" terminal, and it's not for Chevelle only. Any GM car can benefit this.
Old 10-27-2011, 05:07 PM
T-bucket23's Avatar
Wiki Edits: 26
It is normal for the voltage to drop while cranking. Is it the same at the battery. If so then your wiring is most likely ok. 9.5 is a little low, how old is the battery
Chet
Old 10-27-2011, 05:25 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
My voltmeter (dakota digital) drops to 10volts while cranking, after the car has been sitting a month or so.
10.5 after that.
Old 10-27-2011, 07:10 PM
GMR GMR is offline
What seemed bad to me was that I got 9.5v at the solenoid 's' terminal even when I disabled the starter by removing the battery cable so all I hear is the solenoid click.
Thanks for the diagram lg1969.
Thanks for that info Bryan59EC.
T-bucket23, I haven't checked the voltage at the battery during cranking but I will. Thanks.
gm starter solenoid schematics? burnout69 Electrical 5 01-20-2009 08:28 PM
Sparking starter solenoid 1970Chevy Electrical 7 12-13-2007 09:38 PM
SOLENOID vs STARTER J C Electrical 7 10-26-2005 06:48 AM
where is the starter solenoid? 57heaven Electrical 23 08-23-2005 03:08 PM
Remote starter solenoid 49dream Electrical 2 11-29-2004 06:33 PM
