Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Starting Problem
Old 08-18-2012, 12:12 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Sounds like a classic 180 degrees out. Verify #1 is up on compression with the thumb over the hole and the rotor is pointing at #1 tower/wire.
Semper Fi
