-   -   SBC Starting Problem (http://www.hotrodders.com/forum/sbc-starting-problem-223027.html)
Manzasbc 08-18-2012 10:44 AM
I have a manze with a sbc 400 bored out to become a 454.
The car was running great and while driving it one day it just shut off...
I have replaced the coil the ignition modult the whole distributor all the wires and had it trying to start last night but when I retimed it it will now not fire... i retimed it due to the fact is was backfiring through the carb...
all wires are hooked up but on the coil the (-) side reads 4.59 volts and the (+) side reads 11.04 is this correct?
68NovaSS 08-18-2012 01:12 PM
Sounds like a classic 180 degrees out. Verify #1 is up on compression with the thumb over the hole and the rotor is pointing at #1 tower/wire.
Manzasbc 08-18-2012 01:30 PM
it is not even firing now...any ideas
all i did was take the spark plug out and find tdc and reset the distributor....
vinniekq2 08-18-2012 01:49 PM
454? roller cam motor? is the distributor turning? what kind of ignition/distributor?
