SBC starting problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2012, 08:50 PM
New here, spend a while searching for answers and trying this and that with no luck. Heres my problem im hoping somebody can help with. When the engine is cold it will fire right up and run great. Ill shut it off and it wont restart, will back fire thru carb like the timing is off, but if i leave it for the day it will fire up when its stone cold. My base timing is 12* an has 15" of vacuum. Any help would be great, thanks.
engine specs
350, .030 over with stock pistons and bottom end
Comp xe262h-10
Edel performer eps intake
Knock off MSD street fire HEI dizzy
stock 76cc heads
Holley 600 vac secondaries
Holley 12-327 fuel pump
Double roller timing chain
Headman 1 1/2" headers with duals and flowmasters
Starting Problem 2000jack Engine 1 09-18-2012 06:08 AM
SBC Starting Problem Manzasbc Engine 3 08-18-2012 01:49 PM
starting problem chevy c20 Introduce Yourself 1 04-18-2011 09:34 PM
350 SBC starting problem richnkatie1993 Hotrodding Basics 3 01-15-2009 10:14 AM
Engine starting problem..350 sbc.. freeman437 Electrical 5 08-14-2005 09:25 AM
