SBC Still fuel fouling plugs, Losing my mind! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 06:26 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
My 388 sbc is still gas fouling plugs. Ive done everything even changed heads. After 2 or 3 cold starts plugs foul and start poping and missing warms up plugs clear out its ok until its started cold again. Its a 388 has a comp magnum 280 .480 lift. Edelbrock performer rpm heads perf rpm intake, 750 edelbrock carb. It has MSD 6A In good working order has a stock HEI with a externaly mounted Mallory super coil. Spark is very strong. Timing is set @8 deg initial 33 deg total. Ive had the timing every where. Vac advance is not used. Its had 3 different carbs on it.Feul pressure is 6 to 7 psi. Has hooker full lenght headers.I can put new plugs in it start it and take #1 out and it will be sooty black.Im using NGK FR4 plugs gapped at .038, thats the hottest plug I could get from NKG. Its the equivalent of champion RC12YC. Ive turned the mixture screws almost completely closed. Im lost! Does anyone have any other ideas?
Old 09-02-2005, 06:43 PM
347mustang's Avatar
try a different plug brand and what is your fuel pressure set at..should be at or around 6-7 and no higher
Old 09-02-2005, 06:44 PM
King of my Man-cave.
My guess is that the carb is calibrated too rich. Borrow someone's 750 Holley vac. secondary jetted at 72 in the primaries and see if that works.
tom
Old 09-02-2005, 07:17 PM
Bowtie or Die!
I forgot to mention I checked the pressure its mech pump pulsatesbetween 6 and 7 psi. Ive tried autolite,ngk and champion plugs same outcome. gapping them at .038. Tom Ive had 3 differant carbs on it, 750 holley and I exchanged the 750 edelbrock thought maybe the first one was bad, same outcome.
Old 09-02-2005, 08:05 PM
Derkyb's Avatar
Wow! that is strange only thing I would say do is check to make sure you have good engine grounds. What kind of coil have you checked it?
Old 09-02-2005, 08:50 PM
Bowtie or Die!
No I haven't checked the engine for a voltage drop but it cranks good. It has a Mallory coil best you can buy, big as a brick and oil filled.I check the spark with a spark tester spark was like a flame thrower I was turning the dist and I got hit threw the coil wire. I almost fell over I can personally vouch for the spark output! Can a bad engine ground cause this?
Old 09-02-2005, 08:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Yup!
But reading your first post..Sounds more like too much choke on start up..back it off OR don't use it at all for awhile and see if it goes away..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-02-2005, 09:01 PM
Bowtie or Die!
Choke not in use.
Old 09-02-2005, 09:52 PM
T-bucket23's Avatar
Wiki Edits: 26
Fouled plugs
If you are not using a choke at all, maybe the carb is leaking down causing the rich condition while it is shut off and dumping fuel into the intake when it is off. How hard does it start without a choke. If they clear up after it runs a while then the jetting is probably ok. I would check float levels and before you start it next time take a look in the throtle body to see if it is wet. It should be bose dry after sitting for a while. If you have no choke I would not be surprise to get some popping when the engine is coold and running with warm mixture (NO CHOKE), this is noraml and should go away with warm up.
Old 09-02-2005, 09:56 PM
T-bucket23's Avatar
Wiki Edits: 26
Fouled plugs
Have you done a vacuum check. You may have a leak that is sealing up when it heats up. This is not likely but you symptoms are strange. The vacuum gauge may tell a story.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
anyone have any tricks for vaporising fuel for more mileage? sc2dave Engine 185 11-08-2007 03:07 PM
help me i am losing my mind merowe Electrical 1 11-01-2003 11:41 AM
losing dwell and burning plugs spankyway Electrical 2 04-16-2003 04:11 PM
fuel pressure question for a 350 SBC HotRodF100 Engine 15 05-13-2002 03:29 PM
