Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Stocker engine/trans; a couple of questions.
Old 07-12-2010, 07:32 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
I'd throw at least a 30-30 cam in there, with the 1.6 rockers, you are going to need the rpm with the driveline parts you intend to use. I'd use the
"4500" converter, probably only will go 3800 rpm on the 283 anyway.
