Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Stocker engine/trans; a couple of questions.
Old 07-12-2010, 11:27 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Originally Posted by junior stocker
Bought an old Stock Class drag car. My daughter's going to be racing it, so it does'nt need to be very fast.......but........ It ran high 13's to low 14's in it's day, and that will be fine for her to learn with. It's a 220 HP 283, and STOCK; the cam is .398 lift on I/E. I have access to a new set of 1.6 ratio roller rockers; would they be worth the time to install them? The other concern is the converter; swapping to an aluminum Glide, 1.82 first gear unit, trans brake equipped (probably won't be using the brake). The rear gearing is 4.88:1, with a 29 inch tall tire. The 220 HP comes in at 4800 RPM. What would be an approximate stall of the converter I should be looking for? I also have access to a Glide converter, "4500" stall; usable? Thanks.
And yet, you want to make it faster? I'm scratching my head here. It seems your contradicting your first two sentences.
If I were you, I would let my daughter learn with it the way it is and then drop a bigger engine in it. I had a 55 with a 283 and 30/30 solid cam in it and it and even though it sounded good, it wasn't what I was planning on.
And then there was the constant ticking from the rockers.
