Sbc street motor ETs - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2011, 10:48 PM
NovaJoe1973's Avatar
I would like to hear about your "street cars" with a 383 or smaller cubic inch engines and what 1/4 mile (or 1/8 mile) times and how they are set up. Not wanting times on 13:1 motors with huge solid rollers that run on some 50/50 mix gas and calling it a street car cause you drive it to the store to pick up a six pack. I want to hear about a true street car that can and is driven on the street on a regular basis.
Old 12-05-2011, 07:25 PM
Hi Joe,
My street car has a 9.5:1 350, 4 bbl Carter 625 carb, and a manual 4 spd. 3.73 gears and 275 radials. 91/92 octane pump gas only (no race gas or injection). Stock rods/bolts, cast pistons, has not had the heads off in the last 10 years.
I took it to the street drags a few times this summer (set up on front straightaway of an oval track). It's a little short of a full 1/8th, but it's been 5.71 with a 1.30 60' (Powershot plate w/ a .068 Holley jet). Never been on a trailer in the last 15 years.
Where are you in WA?
Old 12-05-2011, 11:31 PM
69 firebird 383 TH 400 3000 stall 4:11 gear 28" tire M/T street.no power steering no power brakes
zz4 block
running zz4 stock cam 474 510 Hdy roller
vor tec heads cut down guides for more lift stock steel rockers
air gap intake 1406 600 carb
msd 6 dig
10:1 pistions with 64 cc heads
headers 3" ext dyno max mufflers axle dump
very mild 13.20 on the motor
12.20 on a 125 shot
2200 ft 100deg day
Old 12-05-2011, 11:57 PM
471A
3100 pound 1929 A sedan, serves as a grocery getter when needed, and runs a best of 10.93 at 120.43 in the quarter mile. Rear gears 3:54. Trans B & M TH 350. Convertor A-1 4,000 stall. Engine SBC 355 w 6 inch rods, 7:5:1 static compression with Ross forged pistons and Dart 220 heads, an RV grind hydraulic roller, Weiand 250 SBC blower (swept volume same as a GMC 4:71), and twin Holley 600 cfm boost referenced carbs. The Weiand blower is basically a 2:53 in configuration, having only two lobes, but its' swept volume roughly equals the GMC 4:71. On the street, I run 29-1/2 inch tall generic radials. On the strip, I run 30 inch tall Goodyear drag radials. I tried street/strip BFGs, but they were a total waste of time and money. The Goodyears turn 1.50 60s and run straight as a string; the BFGs could not even get below 1.80 and were so slippery it was hard to keep the A straight under power. On the street, I run premium pump gas 92 octane. On the strip, seeking to avoid any risk of detonation, I run 112 octane race gas, blended with the 92 already in my tank. The A is driven to the track with the slicks and jack in a carrier bolted to a trailer hitch in the rear of the A then raced once the slicks are bolted on. At day's end, the "basket trailer" for the slicks and jack are then bolted back into the trailer hitch, and we drive back home on the street tires, with the slicks and jack back into the basket. And, last but not least, much of the credit for getting this sedan into the 10s goes to the superb and patient advice I have received over the past several years from the expert commentators on Hotrodders Bulletin Board. So "YES', one can run 10s in an entirely streetable hot rod, set up correctly.
Old 12-06-2011, 01:08 AM
check this bad boy out 500 lb 4,200 460 hp at 5,400 thats gruntin for a daily driver 383 should do 11's on slicks,with pump gas,it's all good!!
http://royalpurple.com/hot-rod-3.html
Old 12-06-2011, 04:22 PM
Originally Posted by aisr
Hi Joe,
I live in Port Orchard. I do most of my racing at Bremerton raceway and sometimes at Pacific.
Old 12-06-2011, 04:31 PM
I lived in tocoma when I was in the army,helped the handelers set up the track at Bremerton do you know terry reed??
Old 12-06-2011, 11:56 PM
Don't know him but the name sounds familiar.
Old 12-07-2011, 05:35 AM
414 cube LT1 4.060" x 4.000"
AFR 227 Eliminators
11.77-compression
PUMP GAS
solid roller 256/260 with .672"/.672"
single plane EFI intake
tight 4400rpm stall
very streetable
10.58 at 128.27 N/A
Still have to get a proper tune on it and get the gearing a little better and go up in stall speed a bit. Hoping for bottom 10's n/a then high 9's in the cool fall air. Car is a '94 Z28. All passes made through mufflers on DOT Hoosier QTP's.
Old 12-08-2011, 05:23 PM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
1995 camaro
LT1 - 10.9:1 comp. afr 190cc heads, xfi280 hydraulic roller cam, lt4 manifold and 52X2 throttle body, 36lb/hr injectors. powered through a t56 and a 12 bolt
runs on premium all day long, not much street use anymore (had a kid so bought something a bit safer) but drives about 50 miles a week anymore. Put 85k on the engine above and still running 11.41 @ 118mph
350 street rod motor kennyhammond Hotrodding Basics 10 12-16-2011 05:05 PM
What is a street motor? Jsup Hotrodding Basics 4 11-09-2009 11:43 AM
ZZ4 cam for street motor??????'s mupton Engine 4 07-23-2009 10:23 PM
What do you think? street motor- rookie builder Hotrodding Basics 32 04-16-2009 08:09 AM
street motor dejo Engine 39 08-18-2006 07:44 AM
