If you order the Summit cam. Order it as a cam+lifter set by adding a "K" to the Summit cam part number instead of ordering separate Sealed power HT817 lifters. The Summit brand SBC Hyd lifters are the same and the value of the cam/lifter package from Summit is hard to beat. There are only a few actual manufacturers that make standard hyd flat tappet lifters. All the engine parts supplyers and aftermarket cam makers draw from these few companies for hyd lifters. Only the low volume production very specialized racing hyd lifters are different. (like Isky's "Superlifter" anti pump up hyd lifter.)
