SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406)
To All,
This is my first post to this Forum and I am dead serious in my search for information . . . I am 45 and have been away from Hot-Rodding since 1990, but am no stranger to the Hobby . . . ;-) I am looking to build a fuel-injected, stroker SBC to drop into a 1989 IROC-Z (Car will retain PS, PB, A/C, etc ), mainly for Street-Driving, but it will see the Dragstrip every now and then, too . . . Transmission will be a 4L80E (Converter to be determined) . . . Rear Axle to be either 12-Bolt Chevy or 9" Ford, Hydraulic Roller Camshaft & Gears will be selected, based on Combination Requirements. I am aware of the 383 vs 406 Arguments . . . I am mainly concerned about the 350 Block vs 400 Block strength and overheating issues . . . I do not want to overbore more than .030", if at all possible . . . HOWEVER, let me introduce the combos I am considering: 383 cid - (350 Block) 4.030" Bore X 3.750" Stroke - 5.7" Rods 406 cid - (400 Block) 4.155" Bore X 3.750" Stroke - 5.7" Rods 409 cid - (350 Block) 4.030" Bore X 4.000" Stroke - 6.0" Rods 428 cid - (400 Block) 4.125" Bore X 4.000" Stroke - 5.7" or 6.0" Rods 434 cid - (400 Block) 4.155" Bore X 4.000" Stroke - 5.7" or 6.0" Rods Desired Compression Ratio - 9.5 -10.5 (nominal for 93 Octane) Edelbrock Pro-Flo RPM Fuel Injection (resize Injectors, as required) Hydraulic Roller Cam (Broad Torque Range) Cylinder Heads (most likely Aluminum, Runner CC Volume, to be determined) Etc, Etc, Etc . . . That 409 really has my attention . . . There are some parameters to help get things started . . . I am looking forward to your input and suggestions ! Dave Fitch Louisburg, NC |
i have a rescent build...(only 450 miles )
might interest you 406=11 to 1 compression...(hates race fuel-92 octane) 511 400 block yes they are strong enough comp cams xtreme 290 grind FLAT SOLID....YOU COULD IMPROVE APON trick flow medium port heads=195 cc.....$1000 worth of porting 527.7 horse all in by 6100 rpm 515 tq @4700 rpm 111volumetric efficiency this is a street motor that idles @ 980 rpm @ 10 in/hg brakes work great here is the part youll love its in a 91 camaro rs 5 speed though .....you may want a whopping 3000 stall contact me if you want more info |
400 overheating
My 350 ran so hot I had to remove the thermostat. I built a 400 and I had to instal a thermostat to keep it up to temp. Make sure the water holes in the head gasket line up with the holes on the head and the block.
Correct me if Im wrong but I believe a 350 with 3.875 stroke bored 0.030 over is a 396. For that kind of stroke {especially 4"
} the clearancing that would have to be done would be wild.Steve |
SBC Strokers - 3.875" Stroke Combos (420 cid)
To All,
The 3.875" Stroke looks very interesting . . . Found this about the Lingenfelter 420 and other motors . . . I like that 2nd 420 motor (COMBO #2) . . . No 3000 RPM Torque Converter need there ! ! ! ************************************************** ******** COMBO #1 420 Cubic Inches: L98 motor Lingenfelter 420, from his book- Modifying Small Block Chevy Engines. 3.875" stroke Callies crank Oliver 5.875" rods 11: 1 compression, custom forged pistons. Used a Bowtie engine block Comp Cams mechanical roller cam: 236/244 @ .050, .549/.549 lift, 110 deg lobe sep, 1.5 roller rocker arms by Comp Cams. Lingenfelter ported AFR 190 aluminum heads SuperRam intake, base, and 58mm throttle body, controlled by DFI using 36lb/hr injectors. Ran test on 1-7/8" open headers. RPM TQ HP 1600 407 124 2000 415 158 2500 478 228 3000 484 277 3500 515 343 4000 534 407 4500 543 465 5000 530 505 5500 498 525 5750 460 508 As you can see from the numbers above, the motor is a torque monster. The combination of the large displacement, smallish heads, high lift roller cam, and the intake system make big block torque in a small block package. This motor computes out to a 113% efficiency at the HP peak, which is an indication of how well matched this combo is. ************************************************** ******** 420 Cubic Inches: L98 motor Lingenfelter 420, from Hi Tech Performance May, 1996 3.875" stroke Lunati 4340 forged steel crank Oliver 5.875" rods 11: 1 compression, JE custom forged pistons. Used a Bowtie engine block Lingenfelter hydraulic roller cam: 219/219 @ .050, .525/.525 lift. 112deg lobe sep, Comp Cams 1.6 ratio stainless steel rocker arms. Lingenfelter CNC ported Brodix Track I heads, 67cc chambers SuperRam intake, base, and 58mm throttle body, controlled by DFI using 30lb/hr injectors. Ran test with Accel 1-3/4" headers. RPM TQ HP 2000 435 165 2500 470 225 3000 520 300 3500 545 365 4000 560 420 4400 561 480 5000 535 502 5200 507 509 5500 475 490 As you can see from the numbers above, the motor is a torque monster. The combination of the large displacement, smallish heads, high lift roller cam, and the intake system make big block torque in a small block package. You can see the differences in the torque and power curves compared to the other 420 motor by Lingenfelter. Even though the engines use the same displacement, intake, and internals; the cam, heads, and injectors are different. ************************************************** ****** WHAT DO YOU GUYS THINK ??? Dave Fitch Louisburg, NC |
************************************************** ******** KOOLAID & All, Yes, an Aftermarket Block is a possibility ! Here is the situation I am starting with . . . Picture a 1989 IROC-Z (No T-Tops) . . . Remove the Engine, Transmission, and Rear Axle and deposit them in the nearest dumpster of your choice (LOL!) . . . Now install a "Stroker" Small-Block (409, 420, etc) with Aftermarket Fuel Injection (I just discovered the "MASS-FLO" System and want to learn more !) . . . Hydraulic Roller Cam (Broad, Flat, Torque Curve 5500-6000 Max. RPM) . . . Compression 9.5 - 11.0 :1 (93 Octane Friendly) . . . Transmission time . . . 4L80E with "Stand-Alone Controller" . . . 2.48 First Gear like a TH400 or optional 2.75 Low First Gear . . . AVOID High-Stall Converter, if possible . . . Rear Axle . . . "POSI", of course . . 12-Bolt Chevrolet or 9" Ford . . . Gears dependent upon Motor Combination . . . NONE of the original GM CPU System will be reused, if at all possible . . . "Get the Picture ?" Everyone's thoughts are welcome ! ! ! Dave Fitch Louisburg, NC Last edited by ez2cdave; 05-21-2007 at 09:23 AM. Reason: typographical error |
I dont understand. How much does the block have to be bored to get 420cu in? How does that all equal 420? Someone help me out here please.
Steve |
New "BULLETS" To Consider . . .
Steve & All, First of all, your question . . . A 3.875" Stroke is combined with a 4.155" Bore to yield 420 cid (421 actually) . . . In the two previous examples, a Bowtie Block was used, which I am sure led to the confusion if you were thinking of a standard 350 Block . . . ************************************************** ******** NOW . . . Check out these "BULLETS" , Guys ! ! ! http://www.shafiroff.com/ http://www.shafiroff.com/shortblocks/406_shortblock.asp http://www.ultrastreet.net/434_realstreet.asp WOO-HOO ! ! ! Dave Fitch Louisburg, NC |
OHHH ok. Yes it was the bowtie block that sent me for a loop. Sorry about that I should have caught on. What would be the biggest displacement you could make from a standard 350 block? Is 4" stroke in a standard block even possible? The biggest I know of is the 396. 3.875 by 4.030, unless of course you went 4.060 or something.
Thanks Steve |
"BULLETS" . . . ! ! !
http://www.shafiroff.com/ http://www.shafiroff.com/shortblocks/406_shortblock.asp http://www.ultrastreet.net/434_realstreet.asp WHAT DO YOU GUYS THINK ??? Dave Fitch Louisburg, NC |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| 350 or 400 sbc | cokeman277296 | Engine | 19 | 03-20-2007 06:39 PM |
| SBC: is it a 350 or 400? | 1984chevrolet | Engine | 3 | 02-07-2007 08:49 PM |
| 400 Sbc With 350 Crank Six Inch Rods | blown volvo | Engine | 53 | 02-17-2006 10:36 AM |
| 350 rods in a 400 sbc | Bandeezee | Engine | 4 | 12-11-2002 05:51 PM |
