sbc temperatur sensor for aluminum heads!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2012, 10:21 AM
(69 camaro) I replaced my 350 with one that has aluminum heads. the stock heads had a sensor with 1/2'' pipe the aluminum heads have 3/8'' hole I'm running with stock gauges and would like to keep it that way. I can't be the first to do this wright!!. need a part number that will work with my stock gauges. called part stores and camaro resto places with not much luck. all come up with 1/2'' stock sensor.
Old 03-14-2012, 10:57 AM
PATH=$PATH\:/usr/local/bin ; e
Look on the manifold, up by the water neck, see if there is a spot you can place the sensor.
Old 03-14-2012, 02:26 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Take the stock sensor to a machinist and have it turned down and re-threaded to 3/8" pipe.
vicrod
flo Tek aluminum heads 67-4-fun Hotrodding Basics 2 09-06-2011 11:28 AM
aluminum heads RatDime Engine 9 07-03-2008 11:48 AM
aluminum heads for sbc dejo Engine 8 08-03-2006 12:32 AM
SBC aluminum heads brainsboy Engine 3 04-26-2006 07:24 AM
aluminum manifold, aluminum heads, bolt torque william27103 Engine 8 11-07-2004 05:46 AM
