SBC threaded oil plug removal help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 11:17 AM
I am trying to remove the 1/4" NPT oil plug just above the oil filter housing. I have tried both 1/4' and 5/16' allen wrenches. The 1/4' seems too small, the the 5/16' seems to big. Is it supposed to be another size, or is the 1/4' correct and just stripped? If so, what is the best method to extract?
Thanks
Old 02-06-2012, 12:06 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What year is it? Have you tried some metrics?
Semper Fi
Old 02-06-2012, 12:11 PM
Its a 79 crate engine. Have not tried metrics but will look into them.
Thanks
Old 02-06-2012, 06:42 PM
Thanks
9/32nds or 7mm ought to get on there.
Bogie
Old 02-06-2012, 06:58 PM
Thanks guys. I did also try a 7mm but it didnt fit so just ended up drilling it and extracted it!
Old 02-06-2012, 09:30 PM
406 bug's Avatar
9.82 @ 139mph
In the future, just use a #9525 Proto extractor. No need to drill.
plug and plug wire removal tcoop Engine 4 10-22-2009 09:01 PM
Freeze plug and engine mount removal Willard083 Engine 2 08-04-2009 11:55 PM
Aren't these supposed to be threaded? 61bone Garage - Tools 2 07-29-2007 01:48 PM
98 V6 S10 #3 Spark Plug Removal COUGARPOWER Electrical 6 03-06-2007 09:33 PM
Plug removal questrion ChevelleSS_LS6 Hotrodding Basics 6 02-23-2007 04:39 PM
