Are sbc throttle body heads & older block compatable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2003, 09:03 AM
Rodrunner's Avatar
Dream as if you'll live 4ever
Location: Roanoke, VA. The Heart of the Blue Ridge Mountians
Post Are sbc throttle body heads & older block compatable?
I just bought a set of heads for my van, Then my van gets flooded, so now I have a brand new set of heads and was wondering if I could use them on an older (1973) block That I'm building to put in my 57 Chevy. The heads have 1.94 intakes. But they are the center bolt kind. The two holes in the center that mount the manifold to the heads are at a different angle than the ones on the ends but that's ok because I'm buying an intake that has adaptors for that. I know you'll ask why would I want to use them, I'm just trying to save me some money, Aren't we all?
Old 03-11-2003, 09:17 AM
DoubleVision's Avatar
Post
yes, they`ll work. The only ones that won`t work on the older blocks are the LT1 and LS1 engines that have reverse flow cooling.
Old 03-11-2003, 03:11 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
You can elongate the center holes to make it fit OK without degrading the sealing surface.
Luv the smell of NITRO in the morning.
