SBC Timing Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2002, 03:54 PM
MI2600's Avatar
Member# 3287
Post SBC Timing Gears
I've got a Cloyes timing gear set and a two-piece timing cover. The instructions for the gear require a .005 to .070 space between the idler gears and the block. I can probably handle that. However, on the front side, if an aftermarket cover is used, the instructions specify a screw of some kind be used to fill the gap between the idler gears and the cover itself. This is apparently to keep the idler gears from walking away from the crank and cam gears. Has anyone installed one of these this way?
Old 09-20-2002, 08:00 PM
Post
I'm not sure how thick the material is on your cover but I've seen where holes were drilled and taped for a bolt and jam nut, not sure if it would work in your application.
