sbc timing with no timing tag - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2007, 09:06 AM
excaliberprime's Avatar
Last journal entry: back for 2014
i have a sbc 350. im trying you adjust the timing after some work i have done to the engine but i m finding it a little hard do to the fact that there is no timing tag around the crank shaft pully. can i by one of these from napa? and if not what do i do know. the engine has hei ingintion. i can get the engine to start but it rives high runs hot then deisels.
Old 04-09-2007, 09:29 AM
SBC with no timing tag
Back to basics guy, remove #1 spark plug, the valve cover on that bank, and bring #1 piston to TDC on the compression stroke by covering the spark plug hole with your finger and watching the rockers to make sure both valves are closed. Once you get the piston up to TDC, install your new timing tag (or before) from your local parts house. (timing tape on the harmonic balancer is a very good idea for accurate timing) Re install the spark plug and time normally with a light. 8-10 degrees initial timing with the vaccuum advance disconnected is a good place to start. You will want 36-38 degrees total timing @3,000RPM once you get initial timing set. Adjustable vaccuum advances are available for about $15.00 to replace your non adjustable one from the stock HEI dist. 2 screws and you are in business there. Hope this helps.
Old 04-09-2007, 09:47 AM
thanks just called my favorite part store not one in stock so i have to wait until tomorrow tried to call a retail parts store but i get short when they keep asking me stupid questions so that there computer can give me an answer so i will wait. the info on how to install the timing tab was great thank you.
Old 04-11-2007, 09:31 PM
Aren't some of them behind the water pump?
Old 04-12-2007, 01:57 PM
timing tab
No, the timing tab and Harmonic Balancer are below the water pump.
Old 04-14-2007, 10:58 PM
There are at least 3 different timing tabs and balancers. 2 are on side in different mounting position and 1 behind water pump.
SBC Timing, the retard way Gladis Engine 2 03-05-2007 04:11 AM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 09:23 PM
What should initial timing be on a 94 350 sbc crate motor? batman09 Engine 4 09-14-2004 07:32 PM
Timing degrees for sbc low77ride Engine 3 11-12-2003 07:49 AM
88' 350 SBC Timing. HOW? help!!! 1966impala Engine 5 10-03-2003 06:09 PM
