Any points distributor belongs in one place, the trash. A HEI out performs points in every way possible. I would also check your harmonic balancer, it`s not uncommon for the outer ring to have slipped giving you incorrect timing readings. most SBC`s live off vacuum advance, the vac advance is supposed to be connected to a manifold or full vacuum source. Lean mixtures burn slower, this is why the high advance at idle (with vac advance) was called for. When I ran my last engine which was a low compression 350, 12 degrees before top dead center with vac advance disconneted and plugged. When plugged in it bumped it up to 24 degrees. With this setting it had excellant throttle responce and power, this was with a road demon jr. 625.
If it pings in your case then the thing to do is retard the spark timing 2 degrees at a time until pinging is no more. |
As noted, even the cheap $45 chinese HEI is ahead of a points dizzy. Yeas, it can idle with vacuum advance coming on, yes your balancer may have slipped, or it may not have. What is your cranking compresion? Low CC can require a little more initial advance.
The first step you need to take is to go to Summitracing.com and get you the in house brand dizzy, they work well and are priced very reasonabley. |
thanks guys, at least i know i'm not alone with the high initial timing setting!
I'm also thinking that maybe the mech advance may be slightly seized, or gummed up it does not seem to advance much, maybe if i give it a clean and lube it might let it swing up to the 36* mark without too much more initial timing. And yes, I have aware of the benefits of a HEI, but I have firewall clearance issues with the Chev HEI, a MSD one is over a thousand bucks in NZ with coil, and and Ignitor module to fit in my current diz is about $260, which is a little out of the budget at the moment so a must persist with stone age technology for the present. Once I have replaced my diff and done the vavle guide seals, then maybe I will start saving for electronic. cheers |
Do you have a electronic choke thermostat? If so, does it have battery voltage with the key on? Your high idle gives me this thought.
What is your point dwell? This will effect your ignition timing. It should be between 27 and 32 degrees. Your vacuum advance will effect this, and a adjustable vacuum advance will help in fine tuning. A manifold vacuum source is the key, and it should be unplugged while setting the initial base timing. Another thought is the point breaker plate, it could be real loose, and giving you a false timing setting. RE: The point dwell effects the timing. Check your choke setting, and throttle cable (unhooked) for binding, and a weak throttle return spring. If you have an automatic trans, check your kick down cable adjustment. (this may be holding it open) |
you can replace the points with a Pertronix replacement. That will do away with the points without the major expense. A Ign box (MSD or the like) can be added later to get the hot spark. Have you had the dist recurved on a distributor machine yet? Looking for 36 total with 12 initial means you need about 14 in the mech advance and 10 in the vac can. In the past I did a lot of them. Start the mech advance about 250 rpm above idle and finish it all at cruise rpm. In my experience you can then use the manifold vac to give you the total you desire while allowing the advance to drop back a little under load. You can play with the split between the mech and vac advance to get the best performance.
The carb should have ample adjustability to set the idle lower, even w/the ignition advanced so check to see what's up with that. To tune the advance curve, you need a set of springs like sold by Mr. Gasket, etc. I don't use the weights (keep the stock ones, at least for now). Replace the OEM springs w/a pair of light ones- just heavy enough to bring the weights back closed when you shut it off. With these light springs, recheck the total advance (w/o vacuum advance for now) by bringing the engine speed up to where the timing quits advancing and see what you get. Initial plus mechanical is what should equal 34-36 degrees. What the vacuum advance adds to that will put you over 34-36 but that's OK- this will only happen for any length of time at cruise (low load) and idle- which is OK, too. This is over-simplified, but will get you headed in the right direction, I think. Main thing it'll do is let you know what your mechanical advance is able to provide. And from that, you can see what (if any) modification to the distributor is needed. |
| setting timing on 350 sbc | elcaminodragster | Engine | 4 | 01-05-2009 08:59 AM |
| What the ***** is wrong with my timing cover/ harmonic balancer!!! | sexypizzaman | Engine | 56 | 10-28-2008 03:49 AM |
| SBC timing issues | Green_Manalishi | Engine | 31 | 02-15-2008 01:33 PM |
| Timing mark question | Kevin45 | Engine | 4 | 07-12-2005 06:46 PM |
| sbc balancer question | STATUTORY GRAPE | Engine | 8 | 07-11-2005 05:59 PM |
