Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC Timing recomendations
Old 12-30-2012, 08:53 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
22 to 26deg base initial ........... 34 to 36deg at max advance.
A limited 10 to 12deg mech advance curve, allows this. limit the adv travel.
+ a 12deg vac advance curve max . the rate has to be found by drive testing.
ported or manifold vac is up to you.
