SBC Timing, the retard way - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2007, 12:38 AM
Gladis's Avatar
So, set the timing, 12 degrees sounded best. It's a over 300-350 hp sbc 350, gen 1. Only problem is that we set everything while the car was in reverse. The SOB started in reverse! We didn't realize because the emergency brake held. When we went to rev it a bit the car jumped a bit and we were like holy s--t! To top it off the car's still on jack stands. So messed with linkage corrected the shifter stuff, now it won't start, backed off the idle rpm too. It just won't start, starter turns, engine turns, coughs a little, sounds like it's not getting fuel, but I can smell the darn gas in air. Any ideas on what we need to change to get this thing started again?
Old 03-02-2007, 01:17 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
The FIRST thing you should be concerned with, IS a proper neutral safety switch installation or clutch over ride...you could have been killed!
Did you check the advance / retard on the dizzy? It may have slipped one way or another when the body was thrashing around..start at mid travel, have some one crank it and advance it if it won't start, retard it..IF it was correct before , you should find the spot pretty easy.
Doc
Old 03-05-2007, 03:11 AM
Gladis's Avatar
thanks I got it right the other day, changed up the linkage too.
400 sbc timing Slant3 Engine 0 07-28-2005 04:28 PM
What should initial timing be on a 94 350 sbc crate motor? batman09 Engine 4 09-14-2004 06:32 PM
Timing degrees for sbc low77ride Engine 3 11-12-2003 06:49 AM
88' 350 SBC Timing. HOW? help!!! 1966impala Engine 5 10-03-2003 05:09 PM
How to set static timing? SBC firing order? CAMARO Engine 4 03-02-2003 03:14 PM
