sbc torque settings for copper head gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2011, 01:02 AM
theg's Avatar
Hi all . Just putting some new heads on my supercharged small block chev . Wondering if 65ftlbs is still the torque setting for copper head gaskets . Ive got ARP stud kit and iron heads . Thanks
Old 01-14-2011, 03:13 AM
DoubleVision's Avatar
If the gasket company that supplied the gasket doesn`t call for a certain torque spec set them to the standard torque spec. If the studs are new, Let the engine run long enough to get it up to temp then retorque them.
Old 01-14-2011, 08:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ARP has a sequence that you have to follow to burnish in new threads before taking the nuts down in steps for the final time. To be sure of the torque required, you should look up the part number of the studs you're using, just to be sure if the specs are the same as OEM.
ARP sez: "Sometimes ARP will recommend using torque specifications that are different than the vehicle manufacturer specifications, but not always." So if you're not sure, give them a shout- their contact info is on the right side of the page linked to below.
You might want to read the info at the ARP SITE, like the section The Lubricant Is The Key.
Old 01-14-2011, 08:52 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Like Cobalt says, ARP studs have two different torque settings, depending on what lube you use on the threads. Do check with the gasket manufacturer, and if using aluminum heads, talk to them as well.
can you run coolant with copper head gaskets? darkostoj Engine 5 11-01-2010 06:37 PM
Copper head gaskets and O-rings LeadfootBob Engine 1 03-05-2008 11:31 AM
using copper head gaskets 347mustang Engine 3 11-28-2005 11:34 AM
Chevy Copper Head Gaskets Thicknesses Canadian Charlie Engine 1 08-14-2005 06:40 PM
Copper Head Gaskets Canadian Charlie Engine 1 08-05-2005 12:32 PM
