Sbc Turbo Build Questions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2013, 12:35 PM
So this morning I woke up and thought a turbo'd 55 Chevy gasser would be cooler then a supercharged one, plus id make more power! And cost about the same. The problem is I don't know where to start, I'm not familiar with turbos! What parts will I all need I know for sure I need a blow through carb or at least convert one to. If I can find a good kit for 2-3 thousand awesome, if I can build something that works that is cheaper even better! The engine is a 9:2:1 flat top 355 010 4 bolt main block, stock short block, small cam its actually perfect for boost 114 lsa, vortec heads, and that's about it. I want something that will work on the stock short block but has room to grow once I build something with forged internals. Any info helps, any junk yard builds with great success I would like to hear too, budget in mind, but don't mind saving and spending 3 grand if it's worth it.
Old 01-27-2013, 12:54 PM
Also looking for 400-450 rwhp maybe 500 on a stock short block.
Old 01-27-2013, 01:28 PM
Banned
you can fab up a decent single turbo system for your budget or less, intercool it if you can, you'll probably only need about 5-10psi and with a really good tune can get away with pump premium (93 octane).
building your own blowthrough carb requires a lot of attention to detail- its not something you want to mess up, and make sure you keep a very close eye on a/f ratios and detonation when you're doing the tuning.
Old 01-27-2013, 01:43 PM
My goal is to keep the car as streetable as possible. 93 and possibly race gas on the weekends
Old 01-27-2013, 02:57 PM
reply
I have a friend who builds turbo kits for a living. try him at his site he'll give ya the info.
WWW.B&GCustomTurbos.com.
Old 01-27-2013, 03:18 PM
techinspector1's Avatar
Wiki Edits: 326
A 350 with flat-top pistons and 64cc heads will be closer to 10.2:1 static compression ratio, not 9.2:1. You have some changes to make before you start puffin' boost into THAT motor.
Old 01-27-2013, 03:52 PM
Factory flat tops? The ones with the 4 eye brows.
Old 01-27-2013, 05:13 PM
Sts would be awesome, but I have no clue where to start.
Old 01-27-2013, 05:19 PM
vinniekq2's Avatar
single or twin turbo? a couple GT-40s on headers can take you a long ways. 700 hp should be no problem.keep your mixture mid 12s for safety. I think 3,000 is optimistic.
Old 01-27-2013, 05:23 PM
Wiki Edits: 326
I might start by reading everything they have written about their product line......
http://ststurbo.com/
Old 01-27-2013, 06:34 PM
Proud LOSER
Excellent read, great insperation....I have read all zillion pages a few times now for a laugh...
http://www.theturboforums.com/thread...ht=the+grenade
Old 01-27-2013, 07:42 PM
I like the idea of a single, twin seems like too much crap in the engine compartment lol
Old 01-27-2013, 07:44 PM
STS Turbo, Inc. - Turbocharged Innovation!
Pretty cool, I'm kind of interested in this set up.
Old 01-27-2013, 07:53 PM
vinniekq2's Avatar
I said twin turbo because that makes it very fast to spool up with reverse facing headers putting 2 little turbos out front. A single turbo is more than enough for decent boost.
Old 01-27-2013, 07:57 PM
How small would I have to go with twins?
Twin Turbo SBC build, need help SBC S-10 Engine 28 09-11-2013 06:10 AM
SBC build questions stealthy1991 Engine 7 05-02-2011 02:48 PM
SBC Twin Turbo Questions gman536 Engine 0 01-30-2010 08:57 PM
SBC Build, Some Questions RandyJ75 Engine 8 06-11-2009 07:08 PM
SBC build questions/comments NWayne Engine 23 03-11-2007 06:02 AM
