Sorry CHEVYRODS i must have skipped over your post some how.. And yes this excatly how i pulled the engine from the motor home! And as far as the engine having a/c or anything else this it did not either.. only alt and powersteering. I did how ever remove the belts when i was pulling the engine and i believe i installed them the way i took them off?? I dont understand factory pulleys being wrong either but I'm not much on v-belt applications either..So if i have to buy other pulleys I will to solve the problem but I dont understand the purpose ? I do understand gears and ratios though and see the point in the reduction of the pulleys sizes also.. But i do appreciate everyones help with this!!
