Originally Posted by gmc1990rodder
So Chris thanks for the diagram!! In this case w/the waterpump pulleys i have (of diff diameter) can i run the alt like you have it shown and the power steering off just the crank? I looked at my buddys 327 and 350"s and they have the same w/p pulleys that i have (one large one smaller)
You could make it work that way. It sounds like the only thing you have set up wrong is the water pump pulley. Once you have the water pump pulley that uses the same size pulleys on it you will be good to go. The fan belt you had driving the PS pump should be long enough to fit the correct water pump pulley once it's on there.
