Originally Posted by V8&4spd
You could make it work that way. It sounds like the only thing you have set up wrong is the water pump pulley. Once you have the water pump pulley that uses the same size pulleys on it you will be good to go. The fan belt you had driving the PS pump should be long enough to fit the correct water pump pulley once it's on there.
Thanks Guys! I really appreciate all the responces and ya'lls help!!!
