Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc V-belt Help Needed
  #61 (permalink)
Old 11-07-2011, 05:20 PM
Chris Kemp Chris Kemp is online now
This one has the right set up on it
Originally Posted by V8&4spd
If you are only running a alternator and PS pump both the pulleys have to be the same size. The crank pulley drives both of them first. If you use the smaller pulley in back the water pump pulley wants to run at 2 different speeds. It's a fact there is a night and day difference when you have the right size pulley on the water pump.
