Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc V-belt Help Needed
  #66 (permalink)
Old 11-07-2011, 06:51 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
Originally Posted by CHEVYRODS
So now another expert that doesn't have a clue. If you look at the picture that you say is correct do you and others see that it has belts on it that don't fit the pulleys. Look at the edges of the belts. Also you are telling the op all the pulleys need to be the same on the water pump so you can now explain how this pulley is correct when it has smaller pulley on front. Come on guys the op has a small belt or alignment problem and now you are wanting him to change everything.
Where is yours
