Sbc V-belt Help Needed - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-06-2011, 05:57 PM
gmc1990rodder's Avatar
LOL sure sure .... Thanks alot 66 I'm sure I'll need more help lol!! thanks again!
  #32 (permalink)
Old 11-06-2011, 06:10 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
As far as setting your belt tension correctly, Dayco has a Krikit Guage
It's a fairly funny video to watch.
  #33 (permalink)
Old 11-06-2011, 06:59 PM
Last journal entry: Paint
Is this the water pump pulley you are using?
  #34 (permalink)
Old 11-06-2011, 08:00 PM
Yes Sir that is the pulley I have on there!
  #35 (permalink)
Old 11-06-2011, 08:20 PM
The pulley is the problem. It will be a night and day difference when you put the right pulleys on there. This is the crank pulley that works with the correct water pump pulley.
  #36 (permalink)
Old 11-06-2011, 08:26 PM
Thanks v8! So the water pump pulley i have is wrong? I need the one that has the same size pulleys on it? And my crank pulley has three equal sized pulleys so this is wrong also? So has someone just changed all of the pulleys?? Thank for your help again!
  #37 (permalink)
Old 11-06-2011, 08:40 PM
If you don't want to scrounge for a factory pulley, you can buy a chrome aftermarket pulley. They make them with the water pump pulley that are the same size.
  #38 (permalink)
Old 11-07-2011, 08:35 AM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
the pulley is not the wrong 1 but you can not run both belts to the crang because its trying to make the waterpump run at 2 different speen just get a shorter belt and take the power steering belt off the crank
  #39 (permalink)
Old 11-07-2011, 08:37 AM
84 stroked ss
its the same setup i have on my monte 1 belt goes from water pump to power steering and 1 belt goes to crank water pump and altenator
  #40 (permalink)
Old 11-07-2011, 08:49 AM
Ok so now I'm confussed...no matter where or how you run the belts they do/are crossing paths at one point or another.. so if one is running at one speed and the other at a different speed they will in turn "fight" each other at some point right?
  #41 (permalink)
Old 11-07-2011, 08:58 AM
84 stroked ss
yes unless you run only 1 belt to the crank
  #42 (permalink)
Old 11-07-2011, 09:08 AM
84 stroked ss
[IMG][/IMG]
this is mine without a power steering belt but just run the power steering belt to the crank to the power steering pump and you will be fine
  #43 (permalink)
Old 11-07-2011, 09:09 AM
84 stroked ss
it will fix your problem
  #44 (permalink)
Old 11-07-2011, 09:17 AM
Perfectly clear now!! Thanks for your help Josh..and thanks for the pic diagram also!!
  #45 (permalink)
Old 11-07-2011, 09:20 AM
Belts And Pulleys
The original belts and pulleys were working just fine on the engine when you took it out. This deal about the having to be same size pulleys is just crazy. There is a purpose on a factory application for the reduced size pulleys. . I'm sure you can find a picture on the net of your exact engine and I will bet you it won't have all the matching pulleys. Somebody has been shopping at speedy Bill's and Jegs to much. Large and small pulleys work just like gear size reduction and speed of what it turns. This is about as crazy as the comment about one belt turning one way and the other one turning the oppisite way. Lets see a picture of how you come up with that one.
What Belt to use? Babyburr General Rodding Tech 8 08-21-2011 10:28 AM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 10:01 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 07:56 PM
belt delsman Engine 4 08-16-2005 12:20 PM
alternator belt diagram NEEDED! StudebakerBob Engine 2 01-29-2005 12:53 PM
