Sbc V-belt Help Needed - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 11-07-2011, 08:20 PM
I sure am glad that V-belts are a thing of the past. The serpentine belts are much better. I'm fifty four years old and I have been turning wrenches all of my life. I'm not the best but I'm good at what I do. I don't advise this to everyone but at the young age of seventeen I quit school and took a full time job as a line mechanic at a local Chevrolet dealership. At that time I was the youngest mechanic in Jacksonville, that worked on commission.
I remember when some of the big luxury cars had as many as seven belts on the front of them. If one of the inside belts broke it was a half a day job replacing it because all of the other belts had to come off. Like I said in an earlier post, "V-belts are not to be taken lightly".
I was about nineteen when I used the wrong pulley on a chevy water pump and it caused the pump shaft to snap and the fan went into the radiator. I had to buy a new pump, pulleys, fan and fan clutch and new radiator. It turned out I had a small shaft pump and a big shaft pulley. Even though the bolts lined up it wasn't enough to keep the pulley centered. It threw everything off just enough to put it out of balance - causing the water pump to snap.
I also know of a young fellow that died because a fan blade came off and stuck him in the chest and into his heart and I also work with a fellow that has a real bad scar on the side of his face where a fan blade came off and cut through his cheek and into his mouth. Pulley arangement and mix matching pulleys is nothing to take lightly. We share a common love, we are all Hotrodders and because of this I love each and everyone of you that are on this post. I would hate it if anyone was to get injured or killed, it is so easy in this trade and I have seen enough of that in my life. Listen to the old man and if you get your feelings hurt then so be it but at least the next time you pick a couple of old pulleys that have been lying around the shop and throw them on the front of an engine you'll give it a little more thought.
  #77 (permalink)
Last journal entry: Paint
If you want a real headache mix a few different year Pontiac pulleys up and try to make them work.
  #78 (permalink)
Old 11-07-2011, 08:21 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Ah Jeez.
The simple fix would to be to go to the wreckers, find an appropriately equipped vehicle ( SBC with v-belt drive. With PS. With double groove alternator, etc, etc, etc.) and then buy the whole kit and kaboodle. That way you'd have matching brackets, pullies, belts ... everything.
Remove, discard your present rat's breakfast, and replace.
That would also make the job of ordering replacement belts a piece of cake. "I need both alternator belts for a 1979 GMC C2500 with a 350 without AC." (for example)
versus
"I have this 350 that has a 3-groove pulley on the crank, and uses that waterpump puley with the 2 different diameters, yada-yada-yada."
In other words ... the "kiss" rule.
"Keep It Simple Stupid"
  #79 (permalink)
Old 11-07-2011, 08:23 PM
Originally Posted by pontiacjosh
it will look similar to this
That will work Josh, but the only thing I dont like about it is that it doesnt give much belt coverage over the water pump pulley. When ever it is possible I like to see the water pump covered on both sides.
  #80 (permalink)
Old 11-07-2011, 08:26 PM
Originally Posted by 66GMC
Ah Jeez.
versus
DITTO ON THAT! I even said this in one of my earlier post.
  #81 (permalink)
Old 11-07-2011, 08:27 PM
Yup I agree LMAO!
  #82 (permalink)
Old 11-07-2011, 08:28 PM
  #83 (permalink)
Old 11-07-2011, 08:41 PM
gmc1990rodder's Avatar
Chris bad thing I also knew a guy that the fan blade went through his chest and killed him...We don't live that far apart hope it isn't the same guy And I'm going to use different pulleys on my engine as well...One thing i know for a fact though is that this isn't a "mutt motor" lol the way it is now is the way it came from factory..sooooo maybe they screwed up somewhere who knows.. I found this engine in a motor home in some 75yr old mans barn it had 11,851 original miles on her and was spotless! I almost fell out when I ask the guy if he wanted to sell the engine..his response was hell son I haven't driven that thing since '77 (which in fact was the year i was born lol) if ya need an engine and you pull her out, you can have it!!! So in trade all he wanted me to do was to get it outta his barn for good!! But long story short you don't find a 400ci sbc 4 bolt main in its original condition often much less FOR FREE!! Thanks for all the post on info from you all! I for sure learned alot from all you guys! And hey if the v-belts don't work out,I gotta a serpintine set up to go right on her!! Thanks again!!
  #84 (permalink)
Old 11-07-2011, 08:48 PM
If you are putting it in a 1990 truck, the PS pump from the 400 is probably set up with a flared steering line. Your truck should have a O ring steering hose end on it
  #85 (permalink)
Old 11-07-2011, 09:04 PM
Ive already put it in my '89 1500 and yea i swapped the hoses over too...my '90 has a modified 5.7(350) in her already..
  #86 (permalink)
Old 11-07-2011, 09:12 PM
The power steering pump in the picture is a 79 with O ring ends. It was from a V6. The V8 power steering pump from a 79 uses flared ends. I can put a quick box in it and use the same power steering hoses.
  #87 (permalink)
Old 11-07-2011, 09:19 PM
I'm not sure I understand V8?
  #88 (permalink)
Old 11-07-2011, 09:27 PM
Sometime around there is when they changed the power steering hose ends. Earlier cars used flared ends for the power steering box and pump. Some of the power steering pumps had flared ends and some had O ring end hose lines. In the 80s you will see mostly O ring ends. When those trucks came out with the serpentine belt system the power steering hose ends were O ring. The quick boxes from the F body cars used O ring ends also.
  #89 (permalink)
Old 11-07-2011, 11:09 PM
66GMC's Avatar
Yep, I believe the change from SAE 45 flare to Metric O-ring fittings occured in 1981.
I figured that out when ordering hoses for my proposed Hydroboost Brake conversion. Why hydroboost, you ask? Because my 454 idles like a can of rocks, and won't have adequate vacuum to run a vacuum brake booster.
  #90 (permalink)
Old 11-08-2011, 04:09 AM
I like Hydroboost - good stuff!
What Belt to use? Babyburr General Rodding Tech 8 08-21-2011 09:28 AM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 09:01 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 06:56 PM
belt delsman Engine 4 08-16-2005 11:20 AM
alternator belt diagram NEEDED! StudebakerBob Engine 2 01-29-2005 11:53 AM
