SBC Vacuum Canister or Pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 07:43 PM
fastnloud's Avatar
My built 350 SBC has a 300 duration cam, and i would like a little more vacuum for the brakes on the truck.
Would a vacuum canister help? I've also read about vacuum pumps, but I don't know how expensive they are or what all i would need to hook it up.
Thanks guys.
Old 03-23-2013, 08:17 PM
BOBCRMAN@aol.com's Avatar
Vac can will usually do the trick. I have a customer that makes the ones I use/sell. Looks like two coffee cans with a check valve.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
fastnloud (03-23-2013)
Old 03-23-2013, 08:58 PM
fastnloud's Avatar
Thanks. I was thinking about getting this one, since it comes with the check valves and fittings.
Summit Racing® Vacuum Reservoirs SUM-G1464 - SummitRacing.com
Old 03-24-2013, 01:22 PM
vacuum
Van canister works just fine. Used them several times without any problems. Far less expensive then a pump.
The Following User Says Thank You to snakebit68 For This Useful Post:
fastnloud (03-24-2013)
Old 03-24-2013, 03:38 PM
Fang16's Avatar
Last journal entry: Project change
Would a vacuum canister store more vacuum than the engine makes? If it has 11 inches of vcauum at idle how can it store enough to make power brakes work? Or, am I looking at this wrong?
The Following User Says Thank You to Fang16 For This Useful Post:
Old 03-24-2013, 06:10 PM
Fang16's Avatar
How good would this work at the track? From the pits to line-up, burn out, staging etc? Wouldn't it take a really big tank for all that?
Old 03-24-2013, 08:30 PM
fastnloud's Avatar
Thanks guys. I have a Holley 750 double pumper on the truck, does the canister hook up to the carb or something else?
Old 03-24-2013, 10:52 PM
vacuum
carb to canister...canister to brake booster. Easy to hook up and yes, it works great at the track and on the street. your constantly creating more vacuum except at idle...so no problems needing giant canisters.
Old 03-25-2013, 08:19 AM
vacuum
Yes, F-Bird'88 is telling you correctly.
Old 03-25-2013, 08:33 AM
Bonneville462's Avatar
I never had any luck with vacuum tanks... The check valve or valves will open with any amount of vaccum..
The only thing that worked for me was to run a piece of steel tubing from the carb base to the booster (with a small amount of hose off the motor for vibration). Remove the vacuum can and adjust the brake pedal ratio to 6 to 1... My brakes work well now with only 9" of vaccum...
I use a 1" bore master cyl...
Vacuum Canister? 84TA406 Engine 12 06-26-2009 11:00 PM
Add a vacuum canister? Brian_B Engine 36 08-14-2007 07:30 PM
vacuum canister or pump novadan Suspension - Brakes - Steering 2 12-08-2006 09:28 PM
Adjustabel vacuum canister? gpeak Engine 18 11-05-2004 10:54 PM
Vacuum canister solgood71blazer General Rodding Tech 3 03-26-2004 07:37 AM
