SBC vacuum too high? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2012, 09:52 AM
After finding and fixing a vacuum leak under my EGR on my crate stock late 70's era 350 I am now getting vacuum of 25 inches in park, and down to about 22 or so in drive (TH350).
This seems pretty high for vacuum but I have not been able to find any info on what ranges vacuum should be for stock SBC setups. I have read to adjust timing for max vacuum, with mixture screw adjustsments, and I get timing in the range of 32-52* total. The higher the timing I go, the more vacuum I see up until the 50* range. I have it set at 36* or so now but it seems to run smoother with more timing. BTW, this is with ported vac (smog insp. coming up).
Thanks
Old 08-01-2012, 10:00 AM
Banned
Whoever told you to do that is an idiot. On a stock sbc you'll want about 14 degrees initial and 36 total (check with vacuum advance unplugged).
Set it there and don't mess with it. Its a stock engine, no reason to "fix it" til you break it.
SBC - How high or low should it be? 31fordcoupe Engine 12 01-24-2012 09:15 PM
high hp low tq sbc blight Engine 61 07-23-2009 06:09 AM
Ridiculously high Vacuum! Tbone714 Engine 12 04-17-2009 12:34 PM
SBC 302--how high can it go? quickervicar Engine 8 11-30-2006 08:35 AM
Vacuum advance on a high-perf. street motor?? hotrodf1 Engine 18 04-03-2006 12:10 PM
