SBC Valve Cover Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2003, 11:42 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I just bought a very nice pair of high polished aluminum valve covers for my SBC 400 (willies36 would be proud, more chrome)! My question is do I need spreaders on these? Also should I use stainless bolts or? This is all part of my engine compartment cleanup anything else I can fix while I'm at it I will. I'll also do the lash adjustments on the valves while I've got the old ones off. Also should I use sealant on the top and bottom of the gasket?
Regards
Mark
Old 10-30-2003, 11:46 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
If they're cast aluminum no, if they're stamped use the spreaders.
I like to put a very thin amount of sealer on the valve cover side of the gasket so that the gasket comes off with the valve cover whenever it's removed.
Old 10-31-2003, 02:50 AM
I like to glue my gaskets to the cover with yellow 3M & use liquid Permatex (Super 300 or Aviation) on the bottom so they come off cleanly. I used to do this on my VW, setting valves every 2000 miles, & rarely had to change the gaskets. I did my Nova that way in 1976, & only ~2" of gasket stuck to the head when I replaced the gaskets a year or two ago. Be sure & use a washer under the bolts with the aluminum covers.
Old 10-31-2003, 03:19 PM
Jag Daddy's Avatar
What type of washers do you recommend? Flat, Star or ???? Also how much torque on the bolts?
Regards
Mark
Old 10-31-2003, 06:03 PM
MI2600's Avatar
Member# 3287
I would use a plastic washer under the screws/bolts. I've got a set of the old Corvette ribbed covers on the '67 and bought the original type phillips-head screws and plastic washers from one of the Corvette parts dealers.
