sbc valve spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2008, 07:12 PM
sbc valve spring
I have a set of chevy heads with the valve spring,what I am calling a cap and a retainer that spins.I have not seen any heads with this setup,if I get
new springs and retainers do I still need to use the caps and spin retainer.
The heads are ported 882 and will be using umbrella seals.
Thanks
Old 07-09-2008, 08:02 PM
No. You can ditch the shields, or caps, if the guides are worn though you might have oil leak past them even with umbrella seals. New retainers will take place of that rotator also. Just make sure the spring seats in the head are the same height, some later heads have an exhaust spring seat that is lower than the intake to make up for the thickness of the rotator, if it's stepped you'll need the rotator or a spacer. I believe earlier versions just used a shorter spring on the exhaust.
Old 07-10-2008, 03:47 AM
Thanks,What you're saying makes sense I didn't understand the sheild and the rotor retainer.
Old 07-10-2008, 11:30 AM
n-gin's Avatar
BrraaAAAAP!
The rotators are on the exhaust side it actually spins the valve to crush carbon on the sealing surface. The Ford 4.9 I6 had these. You can get rid of them if you want you dont need to use them. though I think there is a different spring that goes with those. You will probobly need to pick up a set of retainers and springs if you get rid of the rotators.
Old 07-10-2008, 06:22 PM
I am going to get a new set of springs and retainers just didn't understand
what I had never seen them before.
Thanks
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
sbc 355....no oil pressure to valve train. bigbadbowtie Engine 26 01-27-2006 07:31 AM
Broken valve spring??? Miligav383 Engine 6 05-16-2004 09:40 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
