Sbc Valve Spring Installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2006, 07:20 AM
GoneNova/406's Avatar
i am going to be installing a new set of springs soon and pretty much know how to go about prepping them but have the time now before hand to do a little fishing and see if anyone else has anything to offer that i can use.these are just sbc springs .600's lift 1.265" springs,nothing exotic.thanks.
Old 01-07-2006, 07:43 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
on some fine sandpaper run them in a figure-8 patten on both ends just to knock the high spots. You could also have them checked at the installed height and make sure they are all equal.
Old 01-07-2006, 07:59 AM
thanks.i ran the the springs to begin with that were shipped with the heads since they asked all the info and i had bigger intake valves installed before they sent them and some of the dampers were chewed up.plan to do all you mentioned and radius the spring ends and damper ends and edges.still i am just checking to see if there is something i don't know about.always willing to learn.
Old 01-07-2006, 09:44 AM
King of my Man-cave.
I usually toss the springs into our parts cleaning tumbler for about 10 minutes. Then I compress them fully 3 or 4 times and recheck the tension. Finally, I dip them in SAE30 oil and let them drip off before assembly.
tom
Old 01-07-2006, 09:59 AM
tom i appreaciate the info and the tumbler is a great idea,i think one of my kids has a tumbler from yrs ago that may well do the trick.if i can't find it i can seal them in a tupper ware container and throw it in the dryer with a few rugs.next question is what to put in with them.tom can you help here too?
Old 01-07-2006, 10:37 AM
Our tumbler is a wet-type that uses mineral spirits as a solvent. I don't think that would work well in a dryer. The tumbling media are ballcones. You could probabley use bbs.
tom
Old 01-07-2006, 04:54 PM
i thought you were talking about tumbling that would help to take sharp edges off,like you use to clean bolts and nuts, but yea i thought about bb's or small nuts and a little lite cardboard.thanks for the help
Valve spring ????? 66truck4spd Engine 1 08-25-2005 06:52 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
PCV Valve - SBC - 50's style valve cover spudone Engine 4 10-03-2003 08:22 PM
How much would a machine shop charge to cut bigger valve spring pockets, and...? MuscleTruck Engine 8 06-15-2003 06:17 PM
valve spring installation and removal fordracing Engine 2 04-17-2003 12:49 PM
