Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc Valve stem seals
Old 10-07-2012, 02:50 PM
thinwhiteduke's Avatar
thinwhiteduke thinwhiteduke is offline
Living In The Past
Originally Posted by mud.man.rj View Post
The blue seals on the left are for intake valves the middle umbrella seals with work on both int/exh (not as good as the blue viton seals) and the o rings will work on both int/exh but can't combine with the other 2 seals, I would use viton/blue seals on intake and umbrells on exh, and not the o rings at all.
Thanks mud-man, you've educated me too. Now I know what to used when my crappy little o-ring ones give in!!!
Duke
