Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - SBC valve stem seals and spring compressor
Old 12-14-2010, 01:18 PM
dromero5 dromero5 is offline
Double Vision is right on the money if you can feel play and the clearance on the guides is really more than .004 it is going to suck oil in regardless of the seal you use which is what happened to my heads. I was not aware that you should always have new heads gone through by a machine shop because they all say the quality control is not that good and naturally they would error on the side of using/burning more oil than a tight set up where something is going to seize up. Also if the block has been milled/decked the heads are likely to not seal up if they haven't been machined as well.
