Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc very low oil pressure. Use thicker oil?
Old 01-29-2013, 08:40 PM
GMCTRUCKS's Avatar
GMCTRUCKS GMCTRUCKS is offline
Many of people rebuilt engines but don't do them correct to me building is if the factory would have done with all there specs not just replacing the rings and head work one needs to do all the bearings.
Try Castrol High Mileage oil oh im not saying you didn't do it correct im thinking you had someone do the work for you. Good luck my friend.
Many moons ago a friend of mine rebuilt a 455 HD engine well he had so much blow by he had a water hose atteched to valve cover going under the car that was sad since he had all HD parts he just didn't put it together correct.
