Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sbc very low oil pressure. Use thicker oil?
  #18 (permalink)
Old 01-29-2013, 10:38 PM
shane.,herold shane.,herold is offline
low pressure
I had a fresh 350 with very tight tolerances idle with low pressure but above idle it was fine. It had a standard oil pump. I used to run HD 30w in it in the summer. just make sure its up to temp before you run it hard. I DO think that you should have more than 20 cruising, but it shouldnt fail...
